What characters are forbidden in regular Innovator passwords?
Hi community,
when creating regular Aras accounts (no LDAP) I noticed that certain characters in passwords don´t work.
The user cannot login if certain characters are used in the password, e.g. " or §. Is there an official list of characters to avoid?
Thanks!
  • I want to push this topic to the top of the list again. Does anyone know other restricted characters?
  • Hi Angela,
    Could you let me know what version you're using? I just tested using double quotes " in a password in release 33, and didn't see an issue. I can confirm that the section character (§) does appear to be invalid, however.
  • Hi Chris,
    thanks for testing! I use Innovator 12SP7, but for this thread I use Release 2023 to make comparisons easier. Behavior is identical.
    Your simple mention that " worked in your environment solved the problem. In my case both mentioned characters  " or § tricket me.
    Root cause of the problem: German keyboard layout.
    1. § is a less common char than I thought. It´s not part oft the 128 ASCII table. It´s not even common on keyboards worldwide. I really didn´t know that! Blush Clearly a German thing - even our keyboards have to reflect our love for bureaucracy by providing a dedicated key.Joy
    2. is of course a super common character. But do I really get this char when I use MY keyboard? Well sometimes! For German keyboards it depends on the context. In a programming environment or in this forum I get the straight version ", but in other contexts I get the curly variants and . These two are again not part of the regular ASCII table.
    I made a quick test with a few other chars:
    Work -->  %  $ & ? * ( ) + …
    Fail -->  ö  ä  ß  €  SPACE
     So I assume we can use all regular ASCII 128 letters (without Spacebar).
  • オフライン in reply to AngelaIp
    This would be my assumption as well. I will verify once my test environments are set up, and I can look at the actual logic.
    Edit: It does appear that space characters are valid from my testing of Release 33.
  • I confirm that Space DOES work! I probably mixed it up with another key yesterday.
    We don't assign the passwords ourselves anyway, regular users reuse their Windows login data (LDAP). We've never had any problems with these.
    I only use manual assigned passwords for additional system accounts. Typically for external accounts / tools that access Aras via Rest API. Each use case gets its own very restricted access, which only allows one specific activity.
    I don't think you have to put a lot of effort into this. 99% of the keys on most international keyboards are ASCII 128 anyway. I guess in general nobody uses language specific letters for passwords. Thanks for doing the crosscheck of my mentioned keys! That helped a lot!
