Hi community,
I want to build 6-7 drop downs with similar content. Each single drop down has around 10 values where 7-8 are more or less identical. "Values" are 80% the same for each list, but the "label" has sometimes a different meaning.
The classic solution would be to build six or seven separate List items. Does anyone know any other approach to solve this task without all the List items?
I wonder if we can somehow use a "filter list" for this task. For Filter List the filter condition is typically another property in the ItemType. But in my case I don´t have a second property. The property itself shall define the static filter. Is it somehow possible to specify a static filter for each single Property by default?
The topic is not important and I guess the answer is probably "nope". But it still an interesting topic for a forum discussion :)
BR
