configure email notification
Hi, Requirement : on a document form, we attach some doc files. once we fill up mandate fields, then we type the email or selecting the email from drop down menu list. Once we click on green colour tick mark then the attachment what we attached that should be shared to the email which we provided.   Please help me. how to take it forward.
  • Hello, This should be possible by using a onAfterAdd/onAfterUpdate Server Event on the Document File ItemType. You can check that all of the mandatory fields have some data in them and then use the System.Net.Mail.MailMessage class available through .NET in order to construct your email, attach the related file, and then send the email to your user's email address. You can find a standard example of how to use the MailMessage class to send an email near the bottom of this page outlining the API. One thing to note is that by default, you will need to fully qualify the class path within your server method. Instead of simply using MailMessage as in the example, you will need to use System.Net.Mail.MailMessage. Chris ___________________________________ Christopher Gillis Aras Labs Software Engineer
    • Hey Chris. A few years ago, I successfully deployed the MailMessage class in an Aras method and sent an email with attachment. This was when my Aras instance was on prem. If I move to Enterprise SaaS, is emailing via MailMessage class compatible?
      I am testing this now and it is timing out.
