SOLUTION - PROGRAM MANAGEMENT - How to sum of property over the ITEM Type
AbhishekSrivastava - Friday, October 7, 2016 7:26 AM:
Hi Friends,
If i want to count Items on Item Type then i have a code.
<xsl:stylesheet version="1.0" xmlns:xsl="www.w3.org/.../Transform">
 <xsl:output method="xml" omit-xml-declaration="yes"/>
 <xsl:template match="/"><Result><xsl:value-of select="count(//Item[@type='MACHINE ENTRY'])"/></Result></xsl:template>
</xsl:stylesheet>
Count is successful.
If I have a property name machine_hours and I want to sum machine_hours, so What changes required on above code.
Thanks in Advance
Abhishek Srivastava
edonahue - Monday, October 10, 2016 1:09 PM:
Hi Abhishek,
The XSLT you've provided counts the items of type "MACHINE ENTRY" using the standard XPath count() function. Similarly, you can use the standard XPath sum() function to sum property values from the result.
Example:
<xsl:value-of select="sum(//Item[@type='MACHINE ENTRY']/machine_hours)"/>
Sum function documentation: https://msdn.microsoft.com/en-us/library/ms256160(v=vs.110).aspx
