SUPPORT Q&A - Week start day in calendar
ejmoska - Thursday, June 23, 2016 8:28 AM:
Currently in aras calendar the week starts on Sunday, it is confusing in a working environment where a week starts on monday.
Is it possible to change the first day of the week somewhere?
edonahue - Friday, July 15, 2016 4:26 PM:
Hi ejmoska,
Are you only looking to change the starting day in the date selector dialog? There isn't currently a simple way to configure the start day of the calendar in the Innovator UI, but you may be able to find information online about customizing the Dojo date selector, which the Innovator UI uses.
ejmoska - Monday, July 18, 2016 12:56 AM:
Hello Eli,
Thanks for the answer, but i managed to configure the calendar by changing the locale of Aras. When i changed the locale from en-US to LT , the calendar started showing correctly. Also all the dates in the system started showing correct local formatting.
 Apparently Aras innovator uses Windows locale settings, therefore any locale according to this table http://www.science.co.il/Language/Locale-codes.asp
can be set and it should show correct local formatting.
