DEVELOPERS FORUM - Error Promomt when Click on custom method to create a project
AbhishekSrivastava - Tuesday, May 24, 2016 1:52 AM:
Hello friends,
I am try to create a project from other item type name "TestItem" by creating a custom method name "Create a Project" on Action menu So when i click then it prompts error
" error=TypeError: srcNode is null"
Method as shown  below
try{
var inn=this.newInnovator();
var TestItem=this.newItem("TestItem","get");
TestItem.setAttribute("select","id","project_name");
TestItem.setID(this.getID());
var TestItems=TestItem.apply();
if(TestItems.isError())
top.aras.AlertError("Error:"+TestItems.getErrorDetail());
var Project=top.aras.newItem("Project","add");
top.aras.setItemProperty(Project,"name",this.getProperty("project_name"))
top.aras.uiShowItemEx(Project,"tab view",true);
catch(e)
top.aras.AlertError("error="+e);
So if anybody have a solution on above query so please help.
Thanks in advance
Abhishek Srivastava
Yoann Maingon - Saturday, June 11, 2016 11:45 AM:
1) why do you query your TestItem which I believe is already your context??
2) this TestItem.setAttribute("select","id","project_name"); shoudl be TestItem.setAttribute("select","id,project_name");
3) you create an Item but you don't execute it's creation using the item.apply() method
This may work
Project.setProperty("name",this.getProperty("project_name"))
Project = Project.apply();
top.aras.uiShowItemEx(Project.getItemByIndex(0).node,"tab view",true);
