Jane - Monday, May 16, 2016 4:15 PM:
I need to have a html form with upper and lower sections, each section has multiple tabs.
The ARAS form builder seems not supporting this layout, if I have to develop a customized form, how to make it work with ARA.
What I need to do is --> when the workflow goes to the last step, the user clicks the assigned task in his/her basket, then this customized form will be displayed with all data fields populated from server.
I am new to ARAS, any suggestion would be helpful.
Yoann Maingon - Monday, June 13, 2016 3:23 AM:
Hi, you requirements seem a bit blury. Remember that you have a framework with a lot of possibilities but don't try to over customise to answer the exact requirement from your users.
With that being said, I would suggest you create a new form with the design you want. There are different ways to add tabs to a form, the best one as of today's Aras client side technology is to use the Dojo tabs technology. I can't give you code, you'll need to dive into dojo.
Not sure I can help more at this stage.
Good luck with the customizing, but I would suggest you challenge you users ;) !
