Variability Management
Hello All,
I created the rule inside the rule editor for a particular variability item. When I try to look this particular rule in the database perspective, there is one column named as 'definition' in the VM_RULE table. This column is mandatory column and it has the XML data of that particular rule.
My question here is, I want to know the sequence of methods from UI side which are getting triggered too create such XML. Could you please help me out here ?
Thanks in advance.
