Building the table
Once the Query Definition is ready, build the Tree Grid View using the following procedure:
  1. Create a new Tree Grid View item and specify a unique Name and select an existing Query Definition to be used.
Figure 3.
Note: The Name of the Tree Grid View is automatically used as the name for the RelationshipType generated later.
  1. Select the Auto Grow on Refresh checkbox to keep the Tree Grid View expanded to the maximum number of grow levels when you do a refresh.
  2. After saving the item, click the Show Editor button on the left sidebar to go into Grid-Editing mode.
Figure 4.
  1. Right-click on each element that should display data in the grid and select Map element.
Figure 5.
  1. Right-click the column header and click Add New Column.
Figure 6.
  1. Right-click the new column, click Change Column Label, and then call it Name.
Figure 7.
  1. Add two more columns named State and Created On.
Figure 8.
  1. Save the Tree Grid View.
