SUPPORT Q&A - Demo Database Login Issue
mahindrasatyam - Wednesday, February 17, 2010 5:00 AM:
Dear Support,
Background:-
We have configured the ARAS 9.1.0 in the following environment
Windows 2003 + II7 + SQL express+.net 3.5 and it is working fine...
The Issue
We have setup up the demo database (_PLM9.1v03). Now when we are trying to login into the demo database it is showing the following error
"Object doesn't support this property or method"
url:172.19.136.84/.../Innovator.aspx
BuildContents
_PLM9.1v03 Pre-Defined PLM Accellerator Pack - with Demo Data - for public download w/o service packs. You must run an upgrade, if you want to run this on service packs higher than SP2 ! After upgrade to SP6 the fix_GridHTML package must be applied.
FilenameSize (bytes)
How To Load the ArasPLMe Demo Database 91 - Step-by-Step.pdf 1239126
PLMe_fix_GridHTML_91_SP6_import_package.zip 11820
InnovatorPLMe910-GM-Rel-0-3-2-package.zip 59263556
Innovator PLMe DemoScript v2.pdf 140590
Anonymous - Saturday, February 20, 2010 6:49 PM:
IIS7 does not support Windows Server 2003.  You should remove it.
Install IIS 6 from the Add/Remove Windows Components and then do a repair on .NET to make sure the connnectors are all in place.
-Chris
mahindrasatyam - Monday, February 22, 2010 1:03 AM:
it was IIS 6 only, i wrongly mentioned II7.
my application is working fine the issue exist only when i select the demo database.
