This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
SUPPORT Q&A - SOAP Error retrieving file from Vault
friske1 - Monday, March 23, 2009 2:18 PM:
My installed version Aras 9.0.1 has been running for over 6 months without a problem but all of a sudden I cannot retrieve vaulted files. I receive the following error.
- <SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
- <SOAP-ENV:Body>
- <SOAP-ENV:Fault>
  <actor>Alert</actor>
  <faultcode>1</faultcode>
  <faultactor />
- <detail>
- <![CDATA[ GetContType: failed to get FileType for pdf (Password is expired)
  </detail>
  </SOAP-ENV:Fault>
  </SOAP-ENV:Body>
  </SOAP-ENV:Envelope>
Any help would be appreciated
friske1 - Tuesday, March 24, 2009 10:16 AM:
I have figured out that the vadmin password expired.  To fix the problem I had to login as vadmin and change the password and then change the password in the VaultServerConfig.xml file.
Thanks again for this forum!
Sean - Tuesday, March 24, 2009 6:44 PM:
Friske1
It appears that you have set Maximum Password Age property on the Vault Admin identity.  If you would like to avoid this problem from happening in the future I would recommend clearing this property.
Sean
